Front Trunk Leak - Part Number
Hi,
I seem to have a water leak into the front trunk. After searching around I think I may have found where the water is entering. There is a space between the fender rubber seal and the trunk gasket seal. You can see this in the pictures below and there is rust starting to form in the same spot.
So, does anyone know the part number for the little rubber fender seal? I looked in the PET and could not find it.
Any help and/or suggestions on how to fix/clean this up would be appreciated.
IHI KING!
There are a few threads that take off the fender or attempt to replace this seal.
https://rennlist.com/forums/964-foru...cowl-seal.html
https://rennlist.com/forums/964-foru...ing-seals.html
https://rennlist.com/forums/964-foru...part-away.html
https://rennlist.com/forums/964-foru...y-process.html
https://rennlist.com/forums/964-foru...r-removal.html
There is a good thread with pics from a (UK?) member who had some rust forming in this area and had it repaired. I had the same thing and once the fender was off, the extent of the rust was surprising.
This is going to be much more than just replacing the seal I'm afraid.
