Who has the coolest wheels/ride height on their 964?
#751
FWIW, those of you with the a$$ squatted may want to check your rake. Front/Rear rake is very important on these cars for proper handling and weight transition when driving.
My picture accentuates the rear rake due to the angle. its more subtle than that. You def don't want to be a$$ down, face up, needs to be face down a$$ up like the song you know?
#752
You may want to check your steering stops, chances are that you have the 6mm ones since your Targa is a 1990. The 10mm steering stops part# 964-347-352-02 that were part of the Technical Bulletin for 17” wheels will prevent rubbing.
DTMLGND (04-27-2020)
#754
I did all sorts of research before making the switch from 16” wheels and didn’t catch this. Hopefully an easy change...
Tarek307 (04-21-2020)
#756
GentlemanRacer (04-20-2020)
#762
LOL! Good job revolution ! One of the most classic RL posts. I hadn’t seen it in a while - thanks for bumping it back up. My 964 on PSS10’s and BBS RS GT’s is in here somewhere but I’ve no idea where.
#764
