Bosch vs Beru
Bosch vs Beru
I am planning on doing a thorough maintenance of the ignition system including plugs, wire, rotors and distributor caps for my 1992 C2 (964)
I found a source which sells both the Bosch and the Beru distributor caps. The Beru is much cheaper by alsmost $40 each x 2 it's a saving of almost $80.
Now, is there a major difference in performance/reliability between the two manufacturers. I know Beru has a long history of fabricating wires for Porsches, and Bosch is not too bad either. Would there be a reason for choosing the pricier Bosch over the Beru Unit?
Stephan
Stephan
When I bought my distributor caps at Design 911, the Bosch and Beru caps are only about $10 different on price:
http://www.design911.co.uk/fu/pt259_...stributor-Cap/
I guess it's just a different pricing structure from their suppliers in the UK vs the USA...
Here is the supplier:
BERU = $37.75
http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
Bosch = $71.50
Its actually a $43.00 difference,....
BERU = $37.75
Bosch = $71.50
During my recent tune-up I had Bosch caps/rotors and Beru wires installed. I originally purchased the far less expensive Bosch wires but my wrench refused to install them. I was able to return them (to Amazon) and had Pelican overnight the Berus to the shop.
