Brake parts
Brake parts
Hi, going to the US in a few weeks and thinking of ordering some brake parts (rotors, pads, calipper service kit) to my hotel in St Joseph Missouri. Which webshop should i purchase from? Pelican parts? And which rotors and pads do you recommend? Got standard C2 calippers..
IHI KING!
There are a lot of brake pad options. Tell us how you use your car. Street, autocross, DE, racing? Also, there are two different versions of the C2 rear caliper. The early cars (90-91) have two pistons and the later cars have four piston versions from the C4.
IHI KING!
I would go with some street pads then such as the textars or metal masters. As for where to buy them? There are a number of good suppliers. You could check the Rennlist sponsor list. For what its worth, I buy my parts from Engine Builders Supply (www.ebsracing.com). They offer great service.
IHI KING!
The C2 fronts have 4 pistons. If you are using the car as a street driver, I would stick with stock rotors. Not sure you would get any benefit from the extra cost of the drilled rotors unless you like the look. I drive my C2 at DE events a few times a year. The stock rotors are sufficient for those. IMHO
I'd recommend you stick with stock rotors and Textar pads. It's the cheapest alternative and gives you the best balance and performance for street driving.
