Who makes rear shock spacers
I have a set of Bilsteins that are for the later model 964, my build date is 2/90
Does anyone make spacers so I can use what I already have?
Here is the full thread
Went down that road last spring, wow did it take some thinking and measurement...
If you do mount a coil over then you can adjust the ride height but you might be limited by the damper travel, I was.
So I mounted a 13 mm spacer which I had manufactured to fit with inner diameter 12mm and this gave me the height I needed. So basically as long as you can fit the bolts on top of the strutmount you will be fine.
If I had just bought another bushing kit for my mono ***** I would have saved some money as I could have used it as spacer. You might want to consider this path.
http://www.rennline.com/Bushing-Kit-.../12MM%20STRUT/
Here is a picture of my solution.
Attachment 514692
Attachment 514692
