Lots done this weekend, but need some help.
OK, I have an update on the top alignment. I've driven the car at least 80 miles a day since Sunday. Some of the roads I drive are pretty bumpy. I got a bit turned around on Tuesday and ended up on a bumpy dirt road. The whole time, I kept thinking that it may have been the easiest way to alight the top.
Tonight, for the first time since Sunday, I opened the top to take some pictures of the seal on top of the windshield. When I closed it, it closed fine. Open, close, open close, no issues. Also, my cab top warning light is now off when the top is closed. Whoo hoo!!! Also of note, I noticed this morning that the passenger side b-pillar was welded in the past. It's not near as nice a job as I had done on the driver's side. Now I know why the top was manual when I bought it.
Now to fix the cruise control cable so my idle doesn't go haywire and cause a CEL. Also, need to fix that cab top warning light so it doesn't stay on when the top is down.
Slicks to mount on spare rims this weekend and magnetic numbers on the way to get ready for the first AX of the year. Also new 993 motor mounts, R134 conversion kit and receiver/drier coming Monday. I should have done all of this in the winter, but even with the heater in the garage, it's so tough to get motivated when the 6 month agony is beating down on the midwest.
No region should let you DE a cab without a rollbar. Some regions will let you AX without one (NCR does if you're not on R tires). Relatively safe at an AX, but there are lots of videos of roll-overs on the track.
DR, I checked out your link and on that page, it says
"Convertibles with factory installed roll bars will be permitted. For all other convertibles a roll bar that meets the “broomstick” test is required."
I can't imagine, even if the cab top is considered a factory installed roll bar, which I doubt it is, that I would feel comfortable risking rolling over with that thing being my protection. Especially considering that I just found the pasasenger side b-pillar was welded and I just had the driver side b-pillar welded.
No plans for a roll bar, so I'll skip the DE's until I get a coupe one day.
