Intro - 90 C4 owner saying hello
Hello there rennlisters. Got mine about a year ago. It is my daily driver and I am having a blast with it. After lurking here for a year thought Id finally introduce myself. First off thanks for this forum. It has been unbelievably helpful in making my car better. Speaking of my car:
1990 Carrera 4 3.8L, LWF, Performance Chip, Primary Bypass, Original D90s and Flag Mirrors! The SUV ride height is for the Colorado roads I drive on - can't imagine it being much lower - barely gets in the garage now. http://agavegroup.com/photos/K/rennlist/mycar1.jpg http://agavegroup.com/photos/K/rennlist/mycar2.jpg I have been into air-cooled cars since before I could drive. My other vehicle is a 65 microbus that I have essentially redone everything on. (Not quite as good as the C4 in the snow) http://agavegroup.com/photos/K/rennlist/bus1.jpg http://agavegroup.com/photos/K/rennlist/bus2.jpg Work done so far: New tires (Bridgestone RE050A Pole Position for summer and Blizzak WS60 for winter stock sizes) and alignment Full tune up (valves and all including all new fluids everywhere) Clutch slave cylinder and hose replaced (much nicer clutch action) http://agavegroup.com/photos/K/rennlist/clutchslave.jpg Built a scantool (awesome information with this thing) http://agavegroup.com/photos/K/rennlist/scantool.jpg Replaced engine mounts Bad = http://agavegroup.com/photos/K/rennl...ountbefore.jpg Good = http://agavegroup.com/photos/K/rennl...mountafter.jpg Replaced distributor belt (yes I used a pry bar to get it out) http://agavegroup.com/photos/K/rennlist/dist.jpg Replaced Starter (I think that top bolt is even harder to get to when you have the original longer starter on the 89 and 90 years, ugh.) http://agavegroup.com/photos/K/rennl...rterbefore.jpg Resoldered the Clock (clock now runs perfectly) New Coils (no more xmas tree) Vinyl covered the rear pinkish taillights to make them red again (yes I wash my car sometimes) Before = http://agavegroup.com/photos/K/rennlist/lensebefore.jpg After = http://agavegroup.com/photos/K/rennlist/lenseafter.jpg Keyless Entry (Best $40 spent so far Valet 712T works great) Replaced rear blower motor (its nice to have heat in winter) http://agavegroup.com/photos/K/rennl...lowermotor.jpg Primary Bypass (Shnell good sound, easy to install) http://agavegroup.com/photos/K/rennl...marybypass.jpg Welded Secondary Muffler (One in many on the quest for no rattles see how long this lasts. FYI this was damaged before I put on Primary Bypass) http://agavegroup.com/photos/K/rennlist/secondary.jpg Future work to do: Replace fuel inlet (part in garage just need to install hopefully get rid of the fuel smell) Stereo (factory sound is not so grand) Driver Door stop (have to reinforce this one as it started to tear out) Stop driver door wind noise (one of those annoying things) Go drive/learn on a race course (what these things are made for) Perhaps some 17" wheels from a boxster (hmm....) Thanks again for all the info on this forum. Looking forward to future projects and future drives. Great car! |
Impressed with all the work. Welcome to Rennlist. Nice Car not to metion the scenery
Nice car.
Nice car!!
NICE CAR always nice to see some one take the effort and post good pictures especially before and after... very helpful for the undecided on some upgrades or repairs lol...
Welcome aboard! You have been very busy. Don't hesitate to ask for help if you need it.
welcome, thanks for posting all the pictures!
Love the before and after pictures.
Keyless entry - hmm, looking into that one today. Welcome!! |
Impressive. Can you provide info on the vinyl for your rear lenses and keyless entry?
Welcome. Nice car - best color [IMO] and love the flags and D90's!
Originally Posted by Bruce Kaiser
(Post 8377414)
First the keyless entry. This was the best ~$40 and 40 minutes I have spent so far. One of the few things I missed when I got the car. I purchased a DEI Valet 712T from amazon (just search - actually looks like its $60 now...). I chose this one because of the good instructions here: pelican part forum I did the basic install that just locks and unlocks the car. On the 89 to 90 (I think) the locking control box is in the passenger foot well in a little black box held on by one screw. I spliced into these wires using "wire tap in squeeze connectors". If you have a later car - the connections are under the passenger seat with the alarm box as they moved it all into one control box (as in the diagram below). http://agavegroup.com/photos/K/rennl...ylessentry.jpg The above is for a later vehicle but the wire colors are all correct. (The keyless entry comes with instructions, but they leave a lot to be desired.) I was dissapointed at first that I did not set it up to flash the lights, but the German locks are loud when they move, so I have no doubt when the car is locked. |
Originally Posted by NinetyOneC2
(Post 8376751)
Nice car. Probably the best of the series as it's the last year and I'm sure they sorted it all out!
Nice post with the before and afters! |
Originally Posted by mitch9000
(Post 8377563)
I took the lenses off the car so that I didn't have to do it in the cold garage. Just used soapy water and a hair dryer. I definitely got better as I went - tips: No need to squeegee that hard (at first I thought I had to make it stick - just scraps the vinyl) Use a pin to poke holes around little raises in the lense, like around words (gets it much flatter) Use heat (I would bend the vinyl, heat it, hold it there while it cooled, and it would stay - very cool.) The only downside I see is my reverse lights are not quite as bright. Thinking about cutting rectangles where the reverse light are - make it look like a reverse light of a 993 perhaps. Hope that's helpful. |
Originally Posted by Dave White
(Post 8377601)
???? Second year in of 5.
Dan Stern sells brighter reverse lights, $8.20 per bulb.
