URGENT feedback re DROP LINKS pls
Cars in the garage having some work done.
It's a C4 with H&R sway bars.
Problem at front: Sway bar is rubbing against drive shaft.
Apparent solution: Change drop links for RS ones?
What are the findings of C4 owners with H&R sway bars regarding this problem?
Is it possible I've been wrongly supplied with C2 H&R sway bars?
Thanks?
Thanks?
Frank,
AFAIK, sway bars are the same for 2 & 4
Mines a 4 with H&R and my standard droplinks are absolutely fine (well I havent looked but I hope they are!)
RS drop links wont fit on the front because of the driveshafts (or so Ive read)
Mine are at the furthest out mounting point... GT one seem to think moving them to the other mounting point may work...
Do you know what mounting point yours are on?
Also thanks for the info on the RS drop links!
My car is a C2, so probably not much help here, but I installed the RS drops and found they work fine. I don't believe the stock drop links would have worked as the A arm might have been in the way. The (factory 5 way) 24 MM Front bar, barely misses the power steering canister, maybe 2 mm of space there.
Have the KW's been fitted? I just completed the install on mine, and absolutely love them... Best of luck with yours...
Super Duper Moderator
I have a C4 with TRG bars and stock drop-links on the middle of three settings with no rub issues - sounds like it might be a H&R bar issue and worth giving them a call.
Marc
Marc
I spoke to H&R and couple of other places and apparently I'm the only one with the issue... however the garage is going to try the other mounting point... we shall see...
Thanks for all the help.
Frank,
Congrats on the install . I know what you mean about rediscovering familiar corners a-new. I'm getting new tires (Hankook Ventus R-S3) on Friday, then an appointment with the local Geo wizard at some point in the next few weeks. I want to drive the car a little to settle the suspension before taking it in. All very exciting!!! Do you know your bump and rebound settings by chance? I believe they are measured from full hard or closed, then dialed back from there. Again Congrats
Frank,
Absolutely! I'm dying to get a hot film conversion done by then!
