Wish me luck gentlemen.
02-19-2011, 08:08 PM
I will be taking on my biggest DIY yet, changing the exhaust system tomorrow with a catbypass and g-pipe hopefully its as easy as it sounds (it never is though
02-19-2011, 08:14 PM
Dont b soft, its a piece ov cake.
B ready for the loud, the best racket there is!
02-19-2011, 08:17 PM
Good Luck! Make sure you have plenty of alcoholic beverages, PB Blaster and a torch.
02-19-2011, 08:20 PM
Quote:
Originally Posted by
964russ
I aint soft, I'm as hard as Charlie sheen after meeting Janet Jameson.
02-19-2011, 08:21 PM
No luck needed. One of the easiest things you can do.
02-19-2011, 08:22 PM
I forgot to mention if your torching, you should have a the proper fire extinguisher to deal with any potential situation....
campoj2
Alchohol Check
PB Blaster Check
Torch Wait what? Why do I need a torchh
02-19-2011, 08:23 PM
Cosmos, where in Baltimore are you located?
Rusty bolts can be a Biach if you don't have "heat".
02-19-2011, 08:25 PM
campoj2
Who needs heat when I have this.
02-19-2011, 08:31 PM
campoj2
Medfield near Hampden and Roland Park.
02-19-2011, 08:55 PM
Hit the bolts with PB tonight if possible and don't be shy with it either. Do the the g-pipe first, it's easier and will make you feel good about getting something done quick and easy.
02-19-2011, 09:10 PM
HoBoJoe
I only have WD-40 tonight I was going to pick up some PB blaster tomorrow bright and early
02-19-2011, 09:15 PM
Is there any concern in hitting the O2 sensor with PB blaster?
02-19-2011, 09:35 PM
here's what i did, easy peasey..
