Blower Motor Trouble
Does anyone's blower motor loudly growl at them when the car is cold? Turning the fan off doesn't help. I think it's electrical, maybe a ground issue. When I hit a bump, it seems to aggravate the badger in the dash.
also, the radio works intermittently. The unit stays powered, but no sound comes out of the speakers. could the two be related? Thank you so much in advance for your input!
Are you talking about the blower motor in the engine compartment or the fans just behind the dashboard? Do a search, there is a lot of information on the blower motors.
There are 3 motors/fans behind the dash, 1 CCU air sampling fan and 2 A/C fans, if you are lucky your problem is the CCU fan, easy to fix. Like I said do a search and you will find many DIY threads on this subject.
PS. None of these fans can be turned off, they are always powered up when the car is running, the CCU fan does run for about 20 sec. after the engine is shut off.
