964 Forum
c4 transmission seals
Old 02-26-2011, 06:34 PM
altarchsa
User
altarchsa's Avatar
I just checked the level of my gear lube and it was very low. Found lube leaking from the flange /gasket at bellows #10 in your initial post. Frustrating because I just fixed this within the past year. Guess I need to take a closer look to make sure it's not coming from a leaking line, etc., above.
altarchsa is offline
Old 02-27-2011, 12:22 AM
sml
User
how do you check the level?
sml is offline
Old 02-27-2011, 12:54 AM
altarchsa
User
altarchsa's Avatar
Remove the side filler plug. It's full when lube comes up to the hole. If your finger is small enough, you can put it through the hole and bend it downward to see if the level is close.
Quick Reply: c4 transmission seals
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
