Ultimate C4 AWD Setup?
"I would say the goal is to have a great awd system that gives you the benefits of awd with the handling of a C2."
Eh ?
Are you driving on public streets ?
Eh ?
You can drive smoothly at 10/10ths If it engages but doesn't cause nasty understeer or other bad traits but just gives drive to the most approriate wheel where's the problem?
The only thing you can't do with a c4 is have fun doing big powerslides... but that's not about being fast, it's about messing around.
http://www.youtube.com/watch?v=MHUplFL_yy0
Yah I know about the left foot braking trick, it is a good one to learn on the C4.
@Tuscany, the problem is that the system doesn't work to send power to the appropriate wheel at all. It's not that advanced unfortunately. It just locks up the center diff to make sure the car doesn't spin when it senses the rear wheels moving faster than the fronts.
@Velocity, If I had to say I would say that his center diff lock took out the tranny when it failed, but I easily could be wrong. With the center diff lock not working, the tranny and awd drive train should be able to take that abuse I would think. Do you have any more info on him or the car and what happened?
Actually you can, but it will cost you a transmission - the owner of this car is a rennlister
Yah I have seen that thread. Pretty cool, but also very simple. Along the same lines of what I was thinking, except use the current pump and electronics and just make it all electrical, that system is mechanical. Plus I would get ride of the center diff adjustment, I dont think it's needed.
I know that is not the fastest way around the track lol
True, but I suppose that's the point - why overcomplicate when a proven solution is (was?) available. This was basically the system used by the factory and 'copied' by Ruf at least through the CTR2. Plus the system is adjustable, you can set it with a far greater rear torque bias if you choose.
You could try calling around some of the more established shops with race experience in the C4.
But it sounds like you'll just have to get your hands dirty and blaze the trail. Sounds like a cool project, let us know how you make out!
In both Auto-X and track driving, I have not yet had the PDAS system engage. It's my understanding, that a light tap on the brakes will disengage the PDAS.
The C4 can handle a alot of abuse
