Brad Penn - 2 Places with Low Prices
A lot of debate on the subject. Has to do with levels of ZDDP content. Most oils on the market have been reformulated with lower ZDDP due to the affects on the cat. Brad Pen still has a high level of ZDDP which is suppose to be good for these engines.
I am definitely no expert on the subject but am running Brad Penn in my car.
Well, as we all know Brad Pitt and Sean Penn are huge Porsche fans and collectors. Second only to Seinfeld. They wanted the best oil they could buy for thier P-cars. Long story short, they started-up a small business, and as you can now guess, they named the product "Brad Penn".
True story.
True story.
'Indycam' I used the locator and found 1 distributor in Anaheim, Ca. (Roy Miller Freight) who retails it for $60.00 per case. I have been paying $8/qt. and now can save $3/qt. by picking it up in Anaheim.
True story.
True story.
1 Post
Brad Penn- 2 Places with Low Prices
*Accessories Plus; Belmont, Ron (650) 591-2400 Dealer
*Jansen Enterprise; Belmont, Ken (650) 622-9785 Dealer
Hey - I just got my oil report back from Blackstone - with 5600 miles and 14 months in the car the test says I could have run much longer.
How long do any of you run your Brad Penn?
FYI for anyone visiting Summit Point...Quarles Energy in Winchester sells it for $49/case last time I was there (which was just in July). Only about 20 minutes from the track.
Its the old Kendall GT-1 motor oil from Bradford Pennsylvania .
http://www.amref.com/
Is this 100% confirmed? Kendall GT-1 20W50 is definitely still around here in Western PA, and easily available autozone/advance auto for about $3/qt. In fact I've been running it in my DD 325ix for the last 7-8k miles or so. It would be great if it was, I could switch from Brad Penn to it for the 964 and save ~$13, and only have to worry about stocking up on one type of oil for both cars. Now if I could only use the same stuff in the ///M.
The real Kendall GT-1 is now sold as Brad Penn in a Brad Penn bottle .
http://www.mrxmotors.com/index_files/brad_penn.htm
"Some Neat Brad Penn History
This is like the "Green Oil" we all used to know as the Kendall GT-1 and Amalie Pro brands. Witco Chemical, the original refinery owners, sold the Kendall and Amalie naming rights years ago to Sunoco, who sold "Kendall" to Conoco/Phillips and "Amalie" to Barkett Oil Co, and those brand name oils are no longer Pennsylvania Crude based oils.
Brad Penn, Penn Grade 1 oil, is made exclusively from 100% Pennsylvania Crude stocks. It's the only brand left still using these premium stocks. The crude oil is still obtained from within a 200 mi. radius of their refinery in Bradford, PA. Crude stocks from this geographic area offer the highest natural viscosity index of any crude oil. (90-95) A truly remarkable gift to us from nature. Penn Grade 1 is manufactured at the same refinery that used to make the Kendall/Amilie brands, the oldest continually working refinery in America.
Unlike other current inferior "SL" rated performance oils, Penn Grade 1 still incorporates the same Lubrizol Inc. high zinc additive package (SE, engine severe) that we've always relied on for anti-scuff protection, as well as a modern synthetic PAO additive to reduce cold fluid friction. These are the additives that our racing engines need and the 80's and earlier muscle car engines required. A lot of thought & engineering has gone into the formulation of this oil. It's especially GREAT for flat tappet cams."
http://www.bobistheoilguy.com/forums...Number=1099379
http://www.yellowbullet.com/forum/ar...p/t-47443.html
"the kendall nitro 70 is avaiable at autozone.. if you don"t see it on the shelf ask a manager.. they can get it...nothing is better than brad penn in my opinion if your running alky.. they own the old kendall refinery.. the kendall you buy now is JUNK !!!,, cheap dark saudi oil.. will turn to grey pupon immediatly after startup.... sorry to ramble on..."
"I had heard that the Kendall turned to ****... That is why I am looking for a new brand.
Brad Penn seems like the way to go"
http://www.ferrarichat.com/forum/sho...d.php?t=234449
http://www.jalopyjournal.com/forum/s...d.php?t=298517
"Isky recommends the use of only the following motor oils for maximum cam lobe and lifter protection before and after the break-in period because they are the only conventional mineral based oils available with generous levels of the zinc/phosphorous additive package:
•Brad Penn Penn-Grade 1 **The very best of all in our opinion and the only oil refined from 100% Pennsylvania crude. "
The oil that is in the "Kendall GT-1 20W50" bottle you are seeing on the shelf at autozone/advance auto is not the old Kendall GT-1 . ConocoPhillips bought the Kendall name and they are selling their oil under the Kendall name .
Good thing is you can get Brad Penn in most NAPAs in western PA
