HVAC cover / trim alignment
I have a PO's receipt for the blower motors under the dash being replaced, I'm guessing that something went askew in the fitting. Is there some kind of adjustment to raise up the left side of the big hvac unit under the hood so that this trim piece will fit as it should? Or is there something more sinister going on?
There should be a couple of foam rubber blocks stuck on two of the servos under that cover that adjust it so that the foam on the cover butts up against the scuttle panel.
IHI KING!
Nick - When I bought my C2, it was the same way. I glued a 1/4" spacers to the bottom of this cover to make sure it seals that gap. I used some thick rubber washers as spacers. Its been 2 years since and it seems to be holding up well.
