Brake flluid flush/bleed question
I understand to flush/bleed brakes from rear right to front left. My question is should I flush the clutch slave cylinder first and then the brakes, or brakes then slave cylindar??
I'll be flushing the accumulator too...... am I missing anything else flushable so far?? thanks, Jaime |
Originally Posted by ttAmerica RoadsterAWD
(Post 7591239)
I'll be flushing the accumulator too...... am I missing anything else flushable so far?? thanks, Jaime It also helps to use a turkey baster to remove as much fluid form the m/c as possible |
You need to also flush the differential clutches. To do that you must borrow a Bosch tester gadget which cycles the selonoids.
Thanks, guys. doug I don't think I have those clutches..... is this a PDAS thing? cause I don't have PDAS in my car
Jaime |
is this a PDAS thing? cause I don't have PDAS in my car |
