Euro-RS Gearbox / LSD oil
You constantly see guys posting about how the Redline cured their balky shifting issues in 1st and 2nd when the car is cold or in the winter. That's because it's more slippery. That same slickness that's an advantage for the street guys becomes a liability at higher temps. on the track.
Regards,
Matt Monson
Guard Transmission LLC
Matt, are you sure about that; if you read REDLINEs description of this oil HERE it states that is DOES NOT have the friction modifiers.
For a street car that sees weekend track use as a DE vehicle we recommend Mobil1 Delvac or Porsche's factory fill, which these days is made by Shell. They are both reasonably priced and relatively easy to source, at least here in the states they are.
While both of the above oils would also be satisfactory for track use, what we recommend for dedicated racecars is Lubrication Engineers. A number of the Grand Am and PCA teams that we work with have used that oil with great success in their vehicles. They have seen an average of nearly 20 degrees lower gearbox temperatures over the length of a race, which for a PCA enduro is a 1 hour+ and for Grand Am can be 3-6 hours in duration. Heat is what kills these sorts of parts and if it runs cooler it's gonna last longer. However it's probably overkill for a street car, especially since you've got to buy it in 5 gallon pails.
But you know what the best thing about free advice is? One is free to ignore it. It won't hurt my feelings if you choose to use Redline in your car.
Regards,
Matt Monson
Thanks Matt, good advise, I run Delvac in mine and it is staying in there.
Lately there has been a lot of talk of alternatives to the Mobil Delvac 75w-90, mostly because it is not readily available in many area's, including Canada, but I think most application was intended for street use, and that's what I had in mind when talking REDLINE.
there are some many LSD/Noise threads I wasnt sure where to post this .. anyone have some insight?
I'm wondering about what sounds like LSD noise when car in straight line at 4.5k revs and up
Noise sounds as if it is from (middle) back left side of car
It sounds like wind or air .. but it isnt, its the gearbox or diff (clutch in noise gone)
I have recently removed some of the car's internal sound deadening so there may be some impact from that
I'm not talking about the LSD plates chattering at stand still or when doing slow turn or reverse
More like a higher pitched chattering/whirring sound at hi speed (windy or air related sound)
goes away when clutch is depressed; only happens under load
Isn't there when car starts up and drives around but about 1-2km down the highway it seems to 'pop'out
ie once oil warmed, thinned?
Am running Devlac & Cup car gearbox oil additive from Apex Racing
Am pretty sure the noise wasnt there when I first drove post-stripping the interior ... but not sure!
.. it maybe iwas there the whole time
There is a bit of oil on the outside of the diff ... maybe a leak there?
Maybe I should just change oil ... but I did in Nov 2013 ie 3,000kms ago
thanks Steen, Matt et al
I use castrol saf-xj,my diff has been built by manthey racing very very tight,this is what they use,my gearshift is perfect once hot,take a little longer than mobil oil to get shift a smooth,possibly 2 km
Don't really notice but if being critical
I been using same oil for last 4-5 years approx 30 km,change every second year or when I was using on track every year,comes out spotless every time
Hope this helps
Hope this helps
I checked oil .. full enough and clean ...
changed it and did about 50 laps of Killarney
noise isnt bad, its just not a nice noise (like exhaust is)
