Another Oil Question
I have a 93 C2, and I have read that in 1993 the factory started to use Mobile 1 synthetic oil in the cars. I have owned my car now for 1 year and did an oil change with "regular" oil, and I have not had any oil leaks so far. What is everyone's thought about switching to synthetic oil? Will I start seeing leaks now with the thinner oil? Do our cars need conventional oils (Bradpenn) to function better? Any thoughts are appreciated.
"SEARCH" is your friend, there are hundreds of threads and thousands of opinions on this same subject, please do not start another debate. You will find all the info you need if you use the search botton.
http://www.lnengineering.com/oil.html
Thank you everyone for your help. I have searched/read the many posts on this site in regards to this issue. Wellcraft, I don't have any prior records of oil changes done, except for when I had it done last year when I bought the car. I believe that it was done with conventional oil.
Burgled
