Stock Chip Serial # for Bosch ECU 0 261 200 473?
What Stock Chip Serial # Range should I be looking for? Bosch
ECU 0 261 200 473 (94' C2) Thanks, JF |
1 Attachment(s)
Joseph,
Kinda' cutting it close. Race is only a few weeks away. :) Good question. Some of the chips are interchangeable but the majority are not. It also looks like you can use a couple of different stock chips with your particular ECU. You may want to post your search here--lots of folks have switched to an aftermarket item. You can also use a Steve Wong or other aftermarket chip since you're running Prepared H, right? |
Joey:
Thanks, that's the info I was looking for, this is for my 94' Cab that I'm returning to stock from an Autothority MAF. Is the "Chksum" relevant? If so where can I find it for my ecu? I have a Steve Weiner-Rennsport Systems 100 octane race gas chip for the race car. JF |
Ah yes, you have two 964's. Sounds like you've got the race car covered. Have you raced the 964, yet? Last time I saw you at Gingerman, I think you were still campaigning a water-cooled example.
As for the "Chksum," I'm not sure what that is and whether it makes a difference. Anyone? |
The Checksum is only relevant to a person making a chip and you cannot find it without an EPROM burner.
Its a way for us to ensure that the chip will start the car,...:) :) |
In computer programming generally, a checksum is one simple means of ensuring that the data was probably not garbled during the chip making process or later. A simple checksum is literally the sum of all the data bytes. You add them up and ignore overflow, just let it wrap around. If that number matches one that was stored during programming, then the odds are pretty high that nothing changed. We could checksum this paragraph of text by adding up all the letters' ASCII value (each letter has a numeric value), and if it matches, then Rennlist did not lose data on its server, nor in transmission over the internet.
Code:
; Calculate EPROM Checksum 0x0000 - 0x7EFE |
Originally Posted by JasonAndreas
(Post 7523472)
Code:
"Its a way for us to ensure that the chip will start the car,"
Actually, the engine will start with an incorrect checksum, but will produce a fault code in the DME: movc A, @A+DPTR ; 62A5 = Fault Code 41 Control unit faulty and then; lcall STORE_FAULT_CODE |
Not always,......
OBD-2 cars will generally not start with incorrect checksums. BTDT,...:) |
