Anyone have the "while your in there" threads bookmarked?
Want to make sure I cover all the bases before the engine goes back in and this would be a great reference.
Thanks!
Thanks!
IHI KING!
Is this what your are looking for? I see three threads of that theme.
https://rennlist.com/forums/964-foru...ne-is-out.html
https://rennlist.com/forums/964-foru...y-cheaper.html
Code:
Engine Drop . . while you're in there URL to Rennlist Thread https://rennlist.com/forums/964-foru...ml#post6646775 Clutch, flywheel and fork Check the clutch fork shaft and bearings Clutch slave cylinder and cylinder hose Valve covers check, replace seals Valve adjustment New spark plugs, plug wires Power steering pump belt Engine mounts Oil lines (in rear wheel well) Change the RMS All seals Secondary distributor drive belt Power steering pump o-rings Change the power steering reservoir supply hose Crankshaft seals Blow out the cooling fins Fuel filter and alternator AC and cooling fan belts Inspect the rear suspension CV boots shocks, etc. Check engine tin Starter motor Insulation blanket Oil temp and pressure senders and seals Crankcase breather line on top of engine Alternator motor Hot air lines from engine to chassis Clean/replace injectors Bead blast cooling fan R & R ISV and clean well. Replace tranmission input shaft seal Change tranny fluid Clean and degrease engine and engine compartment, detail as necessary Clearance AC bracket so it can come off without removing front vibration dampener next time around Sandblast and satin black powdercoat all engine tin, rear motor mount, and muffler brackets R & R intake manifolds and clean gunk from insides New lock nuts on exhaust manifolds and valve covers, etc.
Here's another one that I used. I just got done doing 90% of the above list. Let me know if you have any questions.
https://rennlist.com/forums/964-foru...s-learned.html
