What is the best way to clean the oil tank?
My oil tank is out of the car.
I'd like to clean the inside.
I can seal the holes.
Then what should I use to clean out out?
Gasoline?
Kerosine?
Acetone?
Thanks advance,
Dave
Gasoline?
Kerosine?
Acetone?
Thanks advance,
Dave
Ultra sonic will not work on the inside of the tank unless the put the transducer inside the oil tank or if you mounted the transducer right on the oil tank itself . The ultrasonic waves do not go through metal . The cleaning micro bubbles only form on surfaces in line sight of the transducer .
RL Technical Advisor
Its a very critical step in the engine rebuilding process.
The place you send it to must be doing more than just dropping it into an ultra sonic tank .
