My new '90 Carrera 4
booked it in to JZ Machtech today for KW V3 fitting, told them I want it as low as they are prepared to go which they said would probably be a little lower then RS. Picked up refurbished wheels in anticipation. will post pics when it's done.
Don't get hung up on making the car too low, as it's not always beneficial to the ride or handling. As Dave says, H&R greens can and do overwhelm the standard shocks (they did mine). Don't forget, it's not an RS, so making it just below RS height (even with KW's) may not be a good thing. The RS is different in many others ways. I'd also bear in mind what Dave says about the C4.
Welcome to the club.
Thanks for the comments; mr pg, i live in ware. There are some really good roads out from here.
I know going too low is not really the right thing to do, but like some others on here I am from a VW background and it makes it really hard to resist going as low as possible. 964's just look so good low!
I, too, have the Comfort Seats and would have preferred the Sports Seats, but, hey ho, we make do!!!
Regards
Dave
Hi dave
Just been reading your advice with regards to lowering a C4.
I have only currently done the front but will be doing the rear asap.
I have only used springs.
Would you say it looks too low for a C4? or do I need to measure?
I will definately be thinking about uprating my shocks though when the wallet refills itself...lol
lee
lee
Lee,
Comparing the pictures of your car and mine (on the previous page), I'd guess that mine is slightly lower than yours. Measuring the ride height to the specific suspension points is the only way to be sure.
Once the C4 gets down to RS levels (mine is 7mm above RS) the steering geometry is compromised by the steering arms sitting at the wrong angle with the consequence that suspension movement results in an inevitable steering change, i.e. the well documented "bump steer". This cannot be resolved on a C4 since the normal solution is to fit the RS uprights - OK on a C2 but can't be done on a C4 since they will not accommodate the front drive shafts.
Regards
Dave
Regards
Dave
Should be ok then. I have driven it on sunday and today and haven't felt anything untoward, but new shocks is definately now on my list...eventually!
How do I measure the ride height, which points do I use.
lee
lee
