964 Forum 1989-1994
bump steer kit on steel wheel carriers ?
Old 03-12-2010, 06:25 PM
kos11-12
kos11-12's Avatar
Default bump steer kit on steel wheel carriers ?
hello ,
has anyone fitted the uniball bump steer kit to the steel wheel carriers rather than replacing them by the evo alluminium ones ? I understand one fits at the top and the other underneath, does it fit and does it resolve the bump steer problem ? Thanks for your comments
Konstantin
Old 03-13-2010, 03:16 AM
celal
celal's Avatar
the only choice is evo uprights
Old 03-13-2010, 04:53 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Originally Posted by kos11-12
hello ,
Konstantin
It won't correct bump steer due to the angle of the steering arms on the OEM 964 hub carriers.
EVO tie-rods and hub carriers were designed to work together to correct the steering geometry on a low car. While not adjustable, one can install ERP's outers to the EVO inners to afford a measure of adjustment.
Old 03-13-2010, 08:15 AM
Geoffrey
Geoffrey's Avatar
A lathe helps in getting to where you want...
Old 03-13-2010, 08:49 AM
anto1150
anto1150's Avatar
I think custom-made (properly bent) tie-rods mounted underneath (instead of above) the steering arms of the OEM hub carriers could be a solution.
Old 03-13-2010, 05:34 PM
kos11-12
kos11-12's Avatar
Geoffrey you mean make the right spacer with a lathe, do you think it would work (as well as with evo upright) if fited on top, to correct bump steer?
thanks for your replys guys
Konstantin
Old 03-14-2010, 05:14 AM
VMXWinn
VMXWinn's Avatar
Very interested in this!!!
Quick Reply: bump steer kit on steel wheel carriers ?
