Bought a jump starter...¿any issues to be aware of?
Finally I got myself a Black & Decker jump starter and tire inflator device, seems easy to use and it could solve one of the issues of not using the 964 enough and also be helpful in keeping tires on good pressure levels
Are there any precautions to be aware of before using this appliance?
Should I still use the trickle charger? (remember I only use it for 12 hours at a time to avoid complaints from other parking owners)
Don't let the battery in the jump starter get below 10.5ish volts . Keep it charged up .
Don't hook up the battery cables backwards .
Does the one you have , have an inverter built in ?
What model black and decker did you get ?
Thanks Indy for your help, the Black & Decker model is JU300CB it has 300 amp. power and I think it is not for sale in EEUU. It has a warning lock in case you plug it the wrong way, I don´t really know how to plug it yet but I will read the manual before attempting to use it as a jump starter
The only thing I don´t like of the device is that the manual says the pump is good for inflating 3 regular size tires so I presume it would only be good for one or two 964 tires -or maybe the 4 of them if it is only a top up
IHI KING!
I used to use my battery charger's jump start mode once in a while to jump my 964. But then I had a problem with my CCU. I spoke to Loren about getting it rebuilt, he said that they can be damaged by jump starters supplying too high of a voltage. I then purchased a battery maintainer to keep the battery fresh during winter storage.
His advice was if you have a dead battery, disconnect the battery from the car while charging. Then reconnect and start the car with the battery.
What Henry bought is a "BATTERY:12V 19 AMP HOUR SEALED LEAD-ACID" .
Its not some big bruiser battery charger / car starter .
I think , if I understand , he is going to charge up the 12V 19 AH upstairs and then bring it down to the car to top up the battery in the car .
Henry , it will inflate all four tires if you hook it up to the battery in the car and run the engine .
Indy
The Black and Decker battery has to be charged at home (220v) previously and then you plug it to the car battery with 2 clamps to help the engine starting, if there is any risk of damaging the CCU I will surely prefer not to use it at all...
The car is made to be hooked up to a 12 volt battery .
The battery in the car is much bigger / stronger than the little battery in the black and decker .
Do not worry that the little battery in the black and decker might do some damage .
Do you understand about hooking it up to the car battery and then running the air pump ?
Topping up 4 tires is absolutely not a problem. Inflating the spare will not be a broblem. Inflating 4 totally flat tires may be a problem which is probably why the warning is there.
I took it to be more of a statement about the battery being discharged .
I have three of these pumps and have run them long enough that if they were going to melt down from heat build up , they would have .
I do not know then, mine certainly melted down.
Can I borrow yours for a test?
Regarding the hooking of the Black and Decker device to the car battery I think I got it, you have to plug it like you were going to start the car and needed help, then you start the engine and after that you can
start inflating the tires...am I right?
"I spoke to Loren about getting it rebuilt, he said that they can be damaged by jump starters supplying too high of a voltage. I then purchased a battery maintainer to keep the battery fresh during winter storage.
His advice was if you have a dead battery, disconnect the battery from the car while charging. Then reconnect and start the car with the battery. "
Wise advice! Battery chargers have to put out more than 12volts in order for them to pump current to the battery. My battery charger puts out 35 volts. If the battery is connected and the connection is poor or intermitten between the battery connectors and battery post and you've connect the battery charger to the battery connectors. The 35 volts is being applied to the electronics in the car including the CCU and the over voltage protection on these electronics devices may not be able to protect against such voltages. I also suggest that most of the charging of a dead battery or close to dead battery or for that matter a slightly depleted battery, be done by a charger rather than the alternator.
Bill
Bill
