contaminant in Fuel system
Hi all, I have a 91 964 C2 with about 81K miles. The car sat for a long time and I've been driving it for a few months now trying to fix the things that might have gone bad while sitting for more than 5 years. One think I've noticed as of recent is that it takes a few cranks to start up. While working on a different issue my mechanic opened up the tank and removed the fuel sending unit and he noticed it had some what it appeared to be rust on the fuel sending unit and some at the bottom of the tank. He recommends doing a full tank flush, can someone help me out figuring out what it will cost and hours of labor? Will I need a new tank, as far as I am concern is a plastic tank.
I'm just looking for a second opinion before I let my mechanic work on it. Thanks
RL Technical Advisor
No new tank is needed, of course but I would remind anyone that its bad business to refuel the car when the station is getting resupplied by the tanker trucks. This stirs up all the sediment and settled water and how you wound up with a load of dirt and rust particles in your tank.
Just have them clean it out, replace the fuel filter and you'll be good to go. After that, avoid any filling station when you see the big truck.
Be aware that this fitting is not at the absolute bottom so one should go to some efforts to flush the tank well enough to remove all accumulated water and contaminates.
