964 Forum 1989-1994
Decision - '91 C2 vs '93 C2
Old 02-13-2010, 03:58 AM
Crank
Crank's Avatar
Question Decision - '91 C2 vs '93 C2
What d'you think?
Comparing a '91 and the '93 that are basically identical. Similar amount of miles, similar history, similar maintenance, similar options + features, similar PPI results. Both mostly stock, both with good dry engines and clutches.
The '91 is a nice and unusual color, while the '93 is a common color. The '93 has its factory benefits over a '91 (Aero mirrors, head gaskets, etc).
The '93 is a slightly cleaner car than the '91.
The '91 is ~$3.5k cheaper.
What would you choose?
Old 02-13-2010, 05:08 AM
raspberryroadster
raspberryroadster's Avatar
....which one do you prefer? sound like both really good cars with fine ppi's (if they include leakdowns)
from the factory these were both put together by hand the same way.
imo, go with paint, interior.
Old 02-13-2010, 05:28 AM
ThomasC2
ThomasC2's Avatar
I agree, buy the car YOU like.
Thomas
Old 02-13-2010, 06:21 AM
Henry964
Henry964's Avatar
If both are nice and similar cars go for the newer one, 93s are the best of the breed
Old 02-13-2010, 06:57 AM
pantera43
pantera43's Avatar
I went through a similiar scenario when I purchased my car. Passed on a lot of nice cars because I was stuck on the yrs 92-94. Went to look at a super clean 91 and bought it on the spot with passing PPI. Really liked the Grand Prix White with black interior. It really helped that I could eat off the inner fender wells also.. Go with your heart.
Dan
Old 02-13-2010, 07:03 AM
Carbon Marcus 964
Carbon Marcus 964's Avatar
Location: I´m from Germany 40 miles away of Zuffenhausen Porsche´s hometown
Heho
can I have informations of the one you don´t want to have
Marcus
Old 02-13-2010, 09:55 AM
PNine64
PNine64's Avatar
I focused on the 92/93's as well for the reasons above. When I found a great one in an uncommon color I snatched it up quickly.
Old 02-13-2010, 10:18 AM
augsburg911
augsburg911's Avatar
I would pick the 93. The 93 has the gasket seals done at the factory, the dual-mass flywheel is supposedly more reliable, there is an updated distributor, and the rear brakes are a little better, especially if you are going to track the car. Most of the above things have now been upgraded on almost all the cars, but I bought a 93 because I felt that the factory at the time had figured/worked out all the kinks in the car by that time.
Old 02-13-2010, 10:23 AM
mojo747
mojo747's Avatar
Buy the one that you'll want to look at and be in, since they are both nice cars. You need to use your heart as much as your head. It's a quality of ownership thing. I would buy a color over a year. Repairs are repairs, sooner or later you'll do them all. Changing a color is another thing entirely. I wanted Midnight blue, then silver, then black. Red for me was a no go. Sorry red lovers.
Old 02-13-2010, 10:45 AM
hawk911
hawk911's Avatar
Default yeah - which one speaks to you?
i think unless the voice is a demented one (expensive repairs) these cars speak to you. Which one are you listening to?
Old 02-13-2010, 10:51 AM
pantera43
pantera43's Avatar
Not to start another debate but...
1) The leaking head issue is totally blown out of proportion on the earlier 964 cars. Porsche has always had head issues dating back to the SC with broken head studs. I've seen the later 964 with premature valve guide wear and broken head studs that rarely gets talked about too. There are plenty of 90-91 100,000 mile cars running around that have no head issues.
2) The distributors are all the same. The vent kits are $15 which not all later models have.
3) I track my car with the earlier brakes meaning 2 piston rear 4 front. All I did was flush out the system with Motul 600 brake fluid and install Porterfield R4 pads. Never once boiled them or lost pedal.Its more than adequate to pull me down the front/back straights at VIR and the back straight at Mid Ohio. Unless your a real fast immediate or run the fast group they are more than good. In that case you'd be upgrading your brakes to 9993 TT or better anyway.
It sounds like you have two nice cars to choose from. I don't believe either one would be a bad choice.
Dan
Old 02-13-2010, 11:35 AM
crg53
crg53's Avatar
Go with the one you like. Many 91 models came with the factory upgraded cylinders, including mine, you can tell by the engine serial #, or if there was a problem, is has been fixed by now. PPI PPI PPI. including leak down test. Good luck.
Old 02-13-2010, 11:44 AM
mada1
mada1's Avatar
Get the 93. You will wish you had the updates on the 93 has ever time you see one.
It will be fetch $3500 more on resale if you decide to sell it.
Get a ppi and paint meter check
Old 02-13-2010, 11:46 AM
andrew911
andrew911's Avatar
go with the 93....nicer rims too!
I'm not knocking the 90-91, but I exclusively looked for 92-94 for the updates which I love...and there are also few 92-94 cars making it tougher to find one. If the condition is as you described I think it's worth the $3,500 premium.
Old 02-13-2010, 11:53 AM
joey bagadonuts
joey bagadonuts's Avatar
Go for the car which excites you the most but please make sure to take a look underneath. Cylinders should look like this:
not this ...
Quick Reply: Decision - '91 C2 vs '93 C2
