porsche 964 turbo inertia switch
Hi i have a problem with my porsche i try to start it and it starts for 1-2 seconds but then turns off i was wondering if anyone knows where the inertia switch is located on a 964 so a check that out (i already checked the relays)
p.s A picture will be veru helpful.
Ok,
There is a boost pressure sensorcut off in the back of intercooler It cuts fuel pumps off in an over boost conditon. These do fail and can do what you describe.
there is a ground wire (brown) which you should pull off and ground .Try to start and we go from there.
this is the smaller sensor next to one with the orange cover (sender to boost gauge)
Elliot
Elliot
hi
problem fixed as i couldnt find the switch i bypassed it so the car runs again but another problem has come along with it. The pressure on the dashboard has remain on 0.7 bar , it doesnt go up or down . What does this mean??
Elliot
