FVD LB2 Performance kit race
Hey guys, has anyone tried the FVD LB2 Performance kit ? Airflow meter chip etc. I played around with a Steve Wong chip and despite some good reviews feel zero difference. Also tried a Gpipe which sounded cool but confirmed general opinion that if anything it takes away power. I'm thinking of trying the FVD kit plus a cup pipe. My engine is fresh and standard apart from a cat bypass.. Any views ?
I think you will waste your money and be very disappointed. Spend a few hours and read all the posts. I would go the 9M or supercharger route. The SW chip is about as far as you want to go without getting crazy-expensive. MAF is not needed unless you get serious about bigger cylinders, bigger injectors, wilder cams, and structural upgrades to take the extra heat and mechanical loads.
The fact that the Steve Wong chip didn't do too much perhaps suggests your car already came fitted with a performance Chip?
Did wonder whether a performance chip was ready in, but the markings on it looked very much like the original as described in various posts. The FVD kit looks like a fairly straightforward install. Did you need to make any other mods ?
