RS Flywheel or '89 C4 Flywheel?
Has anyone swapped out their dual-mass flywheel for an '89 C4 flywheel and clutch?
It's not quite as light as an RS flywheel (19lbs vs 12lbs), but it's quite a bit cheaper.
What does an '89 C4 clutch cost? I didn't see one listed on Pelican Parts.
It might not rattle as much as the RS flywheel, since it's a little heavier. Might be a good compromise...
I don't believe it's doable without a lot of extra expense. The bell housing is different on an '89 and I believe the clutch is more expensive. I'm pretty sure there is an issue with the position of the starter ring gear too as well as the starter itself.
Perhaps someone with more practical experience may comment.
Regards
Dave
Regards
Dave
Can't comment on 89 C4 clutch fitting but can comment on the two clutches your looking at.
I installed a RS light weight clutch package and all I can say is that there's a huge difference between the two. Almost half the weight between the two flywheels is substantial. The engine spools up and down a whole quicker. Changes the personality of the engine and its responsiveness.
It all depends on what your intended use of the car is. If its a daily driver imho I'd go for the dual mass clutch. If its for sport(weekend) and track use the light weight clutch package is the way to go. Definitely one of my better upgades. Myself and a few others who have done the upgrade have not experienced the so called clutch rattle.
Dan
Dan
+1. The one time I drove a car with the LWF, I was sold. I did not notice any difference in clutch action, and I do not recall hearing any gear rattle. I did notice a difference in the angular acceleration of the crankshaft.
There is still no LWF in mine. The stock clutch is pretty tough and mine still going strong in the eight years I have driven the car. Sorry, do not know much about swapping to the 89 flywhee. If the difference is 7 lb of rotating mass, that is significant and I would pay to get it.
I recently purchased a 92 C2, came with small modification. One of the mods is LWF. I am not sure what type it is. Pros: engine spools up faster. Cons: I have problem down shifting while trying to toe and heel. Engine doesn't respond to the "heeling". Not just that it revs down too quickly, but i feel like by stepping on gas pedal, it takes 1/2 second for the engine to respond.
Is there a remedy to this?
thanks in advance.
thanks in advance.
Technical Guru
The '89 and the RS flywheels weigh the same. It was the pressure plate that Porsche was using that accounted for the ~7lbs weight differential.
Regards
Dave
In the process of having my clutch replaced(89), the starter is different and the ring gear is mounted different, so you would probably have to change out the the whole clutch assembly and starter. I do get slight gear noise on take up, but only once in a while, and not bad.
Here are some pictures of my clutch and bellhousing for you to look at, the ring gear was removed from the pressure plate (I think?) as it had a few bad teeth, so it is not seen here. I understand that the later ring gears are attached differently, hence the longer starter needed on the later cars?
