Broken headlamp assembly - MacGyver fix
A couple weeks back I noticed my front passenger headlight assembly was loose and at night the headlamp beam pattern would bounce up and down just a bit. Last weekend I finally got around to seeing what the problem is....
After removing the headlamp ring I easily saw that two of the four tabs on the cast aluminum headlamp frame were broken! A quick search for a new assembly (964.199.490.50 009) showed that a replacement would cost $90. Not horrible I guess, but decided to see if a little MacGyver work could solve the problem?
I purchased some epoxy, metal wire and 1/16" X 3/4" flat aluminum and decided to rehabilitate the old assembly... Basically I cut, drilled, and shaped the aluminum strip until the broken side matched the original assembly shape. After a test fit in the fender bucket, I marked the correct position of the aluminum strips and glued everything into place. Somewhat unsure of the epoxy's strength, I decided to drill holes in the assembly and aluminum strips and tie the pieces together with picture frame hanging wire (plus more epoxy on the wire and through the holes).
It might look ugly... but it's hidden and feels very solid, plus saved $90+!
AND, it's a lot of fun playing MacGyver!
I think H4s are detailed in the second row on the headlight diagram below... it think, as obviously I'm too cheap to ditch these glued-up H5s and get real headlights...
No swiss army knife? Or duct tape? - No gum wrapper?
- Fah!
MacGyver would'a made a working Carrera GT with only half the stuff you had at hand.
Slick job.
- Fah!
Slick job.
