ok weekend project questions
I will be adding an amp to the stereo system in the pcar.
Is there somewhere here on how to rmove the speaker from the doors or any advice? Also the back deck.
Thank you in advance.
I am going to keep the speakers just rerun speaker wire
Removing the rear deck is simple. Check the instructions here. (site can be eratic, was fine when I went to get the link but can't get to it now)
As for removal of the front speakers the tweeter guards simply unscrew. You can then access the screws behind that hold them in. However if you are using a new set of component speakers you will need to remove the door panel in order to find a location for the crossovers. And if like mine the speakers are slightly larger you will want to look into putting some holes in the metal around the speaker hole in order to fix the speaker to. That will allow for flexibility in the mounting but also holds the speaker in firmly as aftermarket untis are often much heavier due to the magnets on the back.
The 4 screws are behind the rear seats. Two on each side (vertically spaced) close to the side of the car. If I remember correctly, the rear deck kind of "hooks" in place so after removing the screws you have to kind of lift it a bit from the bottom.
