Anyone had their battery totally drain for no apparent reason.
funny.....yeah battery is connected...the clock doesn't drain too much off the battery and like i said i've had my 964 sit for 5-6 weeks with no drain now that i have replaced the door switches...
OK, so will take the advice on the boards and disconnect the interior, glovebox and lights in the boot (didn't even know there was one).
This used to happen to mine, until I replaced the rubber caps on the light switch plungers in the door jambs, which were completely shot. My theory is that whenever i washed the car, some water would get in and short the contacts.
Now I keep one of those battery condition LED indicators plugged into the cig socket all the time: if I can see the green light I know it's OK (it's also handy for checking the alternator's working while driving). If I know that I'm going to be going away, I plug in a Porsche battery conditioner to the cig socket.
Finally I can get some sleep at night.
**when you disconnect the hot leads(wires)make sure you tape the ends with electrical tape and completely cover the ends so they do not short out and remain a problem
Also, if you have an aftermarket HU, and the alarm system wire on the HU frame isn't taped over properly it will drain the battery. There are write-ups on how to fix this here on rennlist.
