Best fitment for a Duck Tail on a 964? - Page 2 - Rennlist - Porsche Discussion Forums
964 Forum
Sponsored By:
Sponsored By:
Old 01-25-2014, 04:33 PM
Rey Gunn
Rey Gunn's Avatar
Resurrecting this thread to see if a ducktail made for a 964 fits a 76 911. Are the fitments the same? Thanks for any help.
Rey Gunn is offline
Old 01-26-2014, 06:31 AM
964russ
User
964russ's Avatar
No.
Early (pre 89) 911,s have different hinges to a 64.
964russ is offline
Old 01-26-2014, 02:30 PM
Shamus964
User
Shamus964's Avatar
As 964russ says - fitment is different between the two models, but that said, I'm running an 'early' ducktail on my 964 with the factory adapter plates (the same one used to mount the RSA tails).
One would have to measure the mounting holes to verify whether mounting brackets would allow the tail to work. Good luck!
Shamus964 is offline
Old 01-26-2014, 03:16 PM
Rey Gunn
Rey Gunn's Avatar
Thanks for the replies! Will see if changing the hinges will work. Hopefully, the mounting points are in the same place.
Rey Gunn is offline
Old 01-26-2014, 03:48 PM
964russ
User
964russ's Avatar
Either change the hinges to early 911.
Or weld sum brackets on.
Alternatively buy one made a 964.
964russ is offline
Old 01-26-2014, 03:51 PM
964russ
User
964russ's Avatar
"Shamus" you have adapter plates?
Porsche parts?
Do you know the part no?
964russ is offline
Old 01-26-2014, 05:51 PM
964russ
User
964russ's Avatar
Found the adapters.
Just a piece of angle, bolts to hinge then to engine lid.
Off porsche there ú90 each!
964russ is offline
Old 01-27-2014, 03:56 AM
freedman
User
freedman's Avatar
GT Racing adapators rather cheaper (though still a lot for what they are)
https://www.gt-racing.com/products-p...inge-adaptors/
freedman is offline
Old 01-28-2014, 02:51 AM
Shamus964
User
Shamus964's Avatar
Yeah - NLA if memory serves. I bought mine as a set from Ebay with the decklid hinges. I figured I'd go this route since most OEM or aftermarket 911 wings (ala RSA tea tray) would need the brackets.
Old 01-28-2014, 05:03 AM
freedman
User
freedman's Avatar
So the alternative would be to use 3.2 or SC hinges?
Seems like a better idea than adaptors, and cheaper to pick a set up I would have thought
freedman is offline
Old 01-28-2014, 04:47 PM
964russ
User
964russ's Avatar
Hinges vary in price.
Roughly ú100 a pair for early ones.
Cheaper to make them.
964russ is offline
Old 03-12-2014, 04:53 PM
964russ
User
964russ's Avatar
Old thread but relevant.
Bought a ducky for the flash.
Fenn lane ducktail.
Quality of the fibreglass is good, smooth ect.
Fit is a bit more of an issue.
Bolts up ok, opens & shuts fine.
Theres a gap along top edge, below rear window.
As thou its too high. Gap is big enough to fit ya finger in.
Is there an adjustment on the hinge to make it sit lower?
964russ is offline
Quick Reply: Best fitment for a Duck Tail on a 964?
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
