Oil Line, Oil Filter Console to Engine - replacement question
#31
This Stomski Racing kit looks pretty cool. Maybe I should buy it just in case?
#32
The "hot wrench" is the magic. Penetrating oil only works so much. Get those fasteners cherry red with the torch and they come right off...
#33
I don't need to do this repair right now and I do not need to remove my exhaust. I was just reading for information only and thinking, "I have all those tools, I have worked on rusty stuff before, little MAP gas and I'm good."
Having seen the level of stuff John does, if he is recommending a shop for this job I know what I'll do when the time comes.
Good luck.
#34
As mentioned by several others on this thread, map gas alone is not hot enough. You need a little map/oxygen torch or an acetylene torch. I would not do the job without the proper torch. That's when people don't have it hot enough, or didn't use a torch at all, and they break a stud.
At my local air-cooled shop, I don't think they even bother with penetrating oil. They just go straight to the torch. With it, no problems...
I had three fasteners that were not coming off with just penetrating oil. Heat till cherry red, and straight off with the wrench...
#35
As mentioned by several others on this thread, map gas alone is not hot enough. You need a little map/oxygen torch or an acetylene torch. I would not do the job without the proper torch. That's when people don't have it hot enough, or didn't use a torch at all, and they break a stud. At my local air-cooled shop, I don't think they even bother with penetrating oil. They just go straight to the torch. With it, no problems... I had three fasteners that were not coming off with just penetrating oil. Heat till cherry red, and straight off with the wrench...
