Piston Pin Offset
Piston Pin Offset
When I took the Pistons and Cylinders off of my 964-3.6 I noted the direction of the piston by recording what direction I slid the pin, so I'm pretty confidant I know how they came out. Seems to be small (E) marks on the upper sides
The piston pins are offset in the piston, and the offsets are on the high side of both banks. With clockwise rotation I would expect 4-6 To be on the upside, and 1-3 to be offset on the underside.
Maybe I'missing something. How is it supposed to be designed/installed?
Thanks,
Alan
Thanks,
Alan
Thanks,
Alan
Thanks,
Alan
There are supposed to be aftermarket versions w/ correct L/R o/s
RL Technical Advisor
In the past, we have rotated 3 pistons and simply machined the intake pockets to suit, however you lose a bit of compression on that side which is undesirable in any performance application.
For normal street use, I doubt anyone would be able to tell a difference and correcting the offsets does yield benefits in piston/cylinder wear.
Cheers Steve, I thought the standard 964 piston crown was symmetrical. So aftermarket pistons with an increased CR and correctly sided pins would be a sensible and fairly inexpensive mod.
Certainly, one can use an aftermarket piston, however the 2618 ones not last anywhere near as long as the Mahle pistons.
