Perfect Engine Drop...
Some new additions.
Clutch, flywheel and fork
Check the clutch fork shaft and bearings
Clutch slave cylinder and cylinder hose
Valve covers check, replace seals
Valve adjustment
New spark plugs, plug wires
Power steering pump belt
Engine mounts
Oil lines (in rear wheel well)
Change the RMS
All seals
Secondary distributor drive belt
Power steering pump o-rings
Change the power steering reservoir supply hose
Crankshaft seals
Blow out the cooling fins
Fuel filter and alternator
AC and cooling fan belts
Inspect the rear suspension CV boots shocks, etc.
Check engine tin
Starter motor
Insulation blanket
Oil temp and pressure senders and seals
Crankcase breather line on top of engine
Alternator motor
Hot air lines from engine to chassis
Clean/replace injectors
Bead blast cooling fan
R & R ISV and clean well.
Replace tranmission input shaft seal
Change tranny fluid
Clean and degrease engine and engine compartment, detail as necessary
Clearance AC bracket so it can come off without removing front vibration dampener next time around
Sandblast and satin black powdercoat all engine tin, rear motor mount, and muffler brackets
R & R intake manifolds and clean gunk from insides
New lock nuts on exhaust manifolds and valve covers, etc.
Thanks.
Valve adjustment
Engine mounts
Change the RMS
All seals
Crankshaft seals
Check engine tin
Starter motor
Insulation blanket
Alternator motor
Change tranny fluid
Thanks.
