Faulty oil level sensor...
As above, my sensor has given up the fight. I've read on John Miles' site how he bodged a fix, but wanted to know if any of you guys had done the job properly. Do I need to drain the oil? Is fitting the new cable as tough as it looks? Any special tools required?
Any info gratefully recieved,
Cheers,
Mark 90C2.
Cheers,
Mark 90C2.
IHI KING!
I have replaced the oil level sensor on my 964 C2. It wasn't too hard. I did drain the oil but in hindsight, you may be able to do it without doing so.
Key steps
I hope this helps.
Key steps
- Jack up the car
- remove the right rear wheel
- Remove the air cleaner housing
- Clean the oil tank area and fenderwell very well to minimize any dirt falling into the tank.
- Unbolt the oil level sensor
- Cut the retaining plastic tie wraps connecting the oil level sensor wires to the oil lines.
- Disconnect the connector in the engine compartment and push through to the fenderwell.
- Remove sensor
- Installation is the reverse. Be careful not to get any dirt into the oil tank.
I hope this helps.
I also did mine over the summer and did not drain the oil. Rob's instructions look great. One of the bottom 6 studs that hold the cover on broke from corrosion when I removed the cap nut. It has not leaked so far.
Thanks guys, the part is on order and I should have it by Monday.
Rob, where does the wire lead to once in the engine bay please? Mine is pretty filthy under the arches, and I can't really see where it goes. Is it fairly near the oil filter? I guess a good jet wash will be in order!!!!
Thanks again.
Cheers,
Mark. 90C2
Thanks again.
Cheers,
Mark. 90C2
IHI KING!
The wire crosses from the fenderwell to the engine compartment about 12-16" back from the oil tank. Its been about a year since I did it but I would say approximately in line with your drive axle. You need to clean thoroughly around the oil tank because you don't want any dirt entering your oil tank. I cleaned around my oil lines too but still found a lot of silt/dust once I cut the retaining tie wraps to separate the wire from the oil line. A power washer is probably a good idea.
Hi Rob
I am a new 89 C4 owner about 9 months. I love driving my car. it has 80K miles on it. Is there anything special to do to get 230K miles out of the car. That is what I aspire to do. I change the oil meticulously and drive the car as often as I can. I also have to cahnge the hydraulic fluids but have not done that recently. I live right up the road from you in Hopkinton,NH. I have been to the porsche dealership in nashua drooling over the new porsches. I still like the looks of my 964 compared to the 997's.
Cons
Cons
IHI KING!
Hi Rob
Cons
Cons
Congratulations on the "new" car. Maybe we can get together some time.
