Squeaky fan bearing
Squeaky fan bearing
Any suggestions on how to lubricate a squeaky fan/motor bearing on the air supply to the interior of a '92 C2?
I have not removed the gas tank on this car and would assume this is a necessary step to get to the fan, but if there are other options, I would appreciate hearing about them.
I assume you are talking about one of the two fans in front of the dash. I replaced both motors recently and it was not hard. You don't have to remove the entire fuel tank, just the evaporator tank on top. I can send or post instructions if it would help.
I solved this with lithium grease (WD 40 wont work). If access is difficult a long syringe could help.
Apply to the spline at centre , front and back if possible.I managed without pulling it, just sprayed it on,
but a syringe might have been easier in hindsight.
I've also solved (postponed) the problem by lubricating the fans. You really need to pull them out to get the lube into the back bushing. My suggestion is to just replace them. If they are making noise it means they are done.
I picked up the right side from driveline.com for $161.00, and the left side from PAP for $220. That's the lowest I could find. Both were OEM.
Beetle63,
I would be interested in your instructions. Can you e-mail to me at jonhums@yahoo.com? Thanks.
Thanks,
Clay
