Rear reflector/tailight tint: testimonial
#77
This kit is the best cosmetic upgrade I have done to date for only $50, several hours and one Tilburg Brown Ale! Here is a link to the before/after pics...
http://picasaweb.google.com/10014007...at=directlink#
#85
I'm in the UK and have bought a kit from Gus (he's a very helpful chap). I haven't installed yet, but plan to very soon.
Something for us Brits to think about... we may need to cut a template, so the reverse lights aren't covered for the MOT. I'm still thinking of the best solution, but at the moment am guessing the best route could be to cut a couple of pieces of cardboard to size and then cut out with a 'very' sharp blade afterwards. Any other thoughts?
#86
PaulW - Are the reverse lights in the same position as the USA cars - I just want to make sure -
I'll try making a few - The issue is that this hole would have to be lined up over the reverse light. While without the hole you have a little flexibility to move vinyl around to center. Will take a look at wah tcan be done -
#87
Gus.. PM sent also.
#89
As a matter of interest, how much white light shines through when in reverse? I'm guessing it will be quite pink with your kit attached.
#90
And, no doubt, your check's in the mail.
