1990 C4 Roll Bar Diameter
Hi all,
I'm looking to order a set of Powerflex bushes for my '90 C4. Could someone please tell me the diameter for the standard front and rear roll bars. I'm in the process of moving house so everything is in a state of chaos and I don't have time to trawl through the site to get the required info. Anyone who has these on their C4 I would appreciate a little feedback as to whether it's a worthwhile upgrade. Thanks in advance, Neil |
Hey there, on the other side of the globe :)
The C4 has 18mm rear sway bar and i think it is 21mm up front. |
Thanks Jan... much appreciated.
Neil |
PET C4
front Rennlist Quotes: 20mm 89, 90- rear22mm 91- (M030) 18mm -90 20mm 91- What is the best way to start a suspension upgrade program? If wanting improved handling, start with the rear. Change the rear sway bar. On a Carrera 4 install a larger diameter one. 21mm is best. These are found on 1990 model year only Carrera 2. I always recommend with a strut brace to also replace the rear sway bar with a more suitable unit. On a C4 you remove the 18 mm and replace it with a 21 or 22 mm. With a C2 you remove the 21 or 22 mm and replace it with a 18 or 19 mm. If you have a tip you leave the sway bar installed because it is a 19 mm. Add a good set of tyres and then see the difference. |
Thanks for the link and the specs for the front roll bar.
Now I'm in a dilemma... do I order a 21 mm bush kit as well for the rear and hope to pick up a used 21mm roll bar!! Thanks again, Neil |
The C2 guys need the bar you have and you need they bar they have. Sometimes a swap works. If you search you'll see posts asking for swaps. Might be worth a try.
Thanks mate... have posted in the FOR SALE thread...
Neil |
