K&N air filter - good idea?
Professor of Pending Projects
I have one if you want it... I am sticking with factory filters....
EDIT - London... shipping will cost more than the filter....
Last edited by Wachuko; 11-07-2008 at 05:34 PM. Reason: London... shipping will cost more than the filter....
Paper fails conservatively with age by becoming a 'tighter' filtering agent (passages become plugged with particles).
Oiled films OTOH fail (by drying out) by allowing more and more through.
A dry K&N is not the same as your dry paper. Dry K&N 'media' (foam) will allow everything short of sand to get through.
Pass.
[-- doh!]
But JAIME'S is different! [secret wink thrown to Jaime]
His is Great.
Buy it, keep it well cleaned and oiled and I promise, life will be Golden.
Pass.
[-- doh!]
His is Great.
I was planning on ditching my K&N too. My car hesitates a bit upon hard acceleration and the mechanic though it could be because of that. Maybe it is..maybe not...either way quick winter project.
Fortunatly the Previous Owner gave me the stock airbox.
Ok for the track if you don't have a dirty track or run out into the kitty litter too often, but not for the street...I ran one for a while that came with a hot wire setup, and just like my kart filters you would get a fine dust on the inside of the throttle body, replaced with a cone filter and it ran clean...the only way I run a foam is with the additional foam dust sock (for off road applications), by the time you do that I think you've lost any benefit of additional flow of the K&N fliter...
My experience has been that the difference on a dyno between a stock paper filter and a K&N filter is 1-2rwhp. This won't affect the air fuel ratio by a material amount.
