964 service info found
I found some 964 service and technical service files. There is no information about who the publisher or copyright ( if any) holder may be. If you can identify the material please let me know. I will post one section from the transmission section but there are over a thousand pages more..
Spartanic, (http://forums.bimmerforums.com/forum....php?t=1046318), This is copyrighted material from www.alldatadiy.com. Your posting of this material, and offering it for sale is in clear violation of AllDataDIY copyright and trademark rights.
ALLDATA LLC
Terms and Conditions of Use
For ALLDATA Products Consumer Customers
License. Subject to these terms and conditions, ALLDATA LLC (“ALLDATA”) grants you (“You”) a non-exclusive, non-transferable, non-sublicensable license (the “License”) to use certain ALLDATA Product(s) (the “Product”) which have been provided to You by ALLDATA along with accompanying data (the “Data”) and documentation (the “Documentation”). You acknowledge that, as between the parties, ALLDATA retains all rights, title and interest in the Product, Data and Documentation, including without limitation all copyright and trademark rights. You acknowledge that the Software and data constitutes valuable proprietary, confidential and trade secret information of ALLDATA.
Restrictions. The Product, Data and/or Documentation is to be used solely in connection with Your personal use, and not in connection with the business of any other firm, person, organization or any other commercial use. You must not: (i) directly or indirectly, reverse engineer, decompile, disassemble or otherwise attempt to discover the source code or underlying ideas or algorithms of the Product, Data and/or Documentation; (ii) modify, translate, or create derivative works based on the Product, Data and/or Documentation; (iii) copy (except for archival purposes), rent, lease, distribute, assign, or otherwise transfer rights to the Product, Data and/or Documentation; (iv) use, or make available for use, the Product, Data and/or Documentation either (a) on a wide area network or (b) for off-site access; or (v) remove any proprietary notices or labels on the Product, Data and/or Documentation.
Reproduction of Information. You may view, reproduce and/or print insignificant portions of materials retrieved only from the Products provided (a) the materials are used only for informational, non-commercial purposes and (b) You do not remove or obscure the copyright notices or any other notices. You may print invoices, estimates, and quotations from ALLDATA Products which are required to be printed by law provided that such printing does not include Data from the Products. Except as expressly provided for in this paragraph, no part of the Product, Data and/or Documentation, including, but not limited to, materials retrieved therefrom and the underlying code, may be reproduced, re-published, copied, transmitted or otherwise distributed in any form or by any means. In no event shall materials from the Product, Data and/or Documentation be stored in any information storage and/or retrieval system without the prior written permission of ALLDATA LL.
Danz C4
ALLDATA LLC
Danz C4
