Oil changes low milage
Dear All
I have a 1989 C4, which unfortunately I use very rarely (even though I think about it very often).
Last year I drove it for 1500 Km.
What kind of oil change interval would you recommend?
What kind of service and how often?
Please tell me what is your behavior in such circumstances!
F
964 3.3 Turbo (gone)
964C4 (alive and kicking)
F
Agent Orange
Once a year should be enough IMO. Make sure you bring the car to operating temperature every time you drive, however (8 o'clock on the oil temp gauge). That will limit any possible issues with oil condensation and sludge.
Last year, I worked way too much and put about 2000 mi. on the car. Agree on the once-a-year change, that's what I do. When you do drive it, try to get in at least an hour's worth of operating time, so all of that 3 gallons of oil gets thoroughly heated and the moisture cooks off. I also use an upper-cylinder lubricant in the gas for good corrosion protection, and some gas stabilizer as well. 1500km/yr means your petrol ages in the tank for long periods.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I drive my 996TT way less than has been described above (actually sat 2 years at one point)....FWIW I always change the oil right before it goes into storage for the winter.
1 x year, although even at 5000 miles per year my oil still looks golden when I drain it. Also +1 on driving long enough to drive off the condensation that forms each time the engine starts.
Golden? Seriously? I thought the additives in the oils made them turn black within minutes (or hours?) of engine use. Is this not the case?
Agent Orange
Seriously. I avoid short trips, and always get the oil hot enough to drive off condensation. Keeping condensed water/acids out of the oil keeps it looking cleaner for longer. As the engine wears and develops blow-by, the oil will start to get dirty sooner.
Why should one change the oil every year if minimal mileage done? Does it go off? Is there a sell by date on the can like milk? Why not change it every 18 months or 2 years?? I don't understand!
1 Post
Bottom line is, oil changes are cheap preventative maintenance. Why take a chance? I change mine more often than probably necessary, but I would rather err to the side of caution. I figure it can't hurt and can only help.
