erratic temp sensor... about gave me a heart attack
I was coming into the office today a little late so I decided to take the interstate as I was after rush hour. I drove pretty swiftly, but nothing crazy and when I exited the interstate after about 15 miles of Interstate driving, I rolled to a stop at a light and about had a heart attack when I looked down and noticed my temp gauge pointing right up at the red! Oh geeesh! I was staring at it and deciding that I should not cut the engine but should drive around the block a few times to help it cool. The ambient temp today is 50 degrees F (10 C). As I was staring at the gauge it snapped back to about 7 or 8 O'Clock where it typically sits when warm. When I got to the office I felt the front right fender and it was not warm. The rear near the oil tank was warm to the touch, but not hot.
So what's going on? My assumption is that if the car was really 300+ degrees then the rear panel near the oil tank would have been damn hot, not just kinda warm. So I think I can assume that the car was not crazy hot, it was a false reading. This right?
So... Temp sender bad? Gauge issues?
As usual, I turn to Jason's pics and answers.
First hit the gauge's pins w/ eraser, then go after sender.
Looks to be a single pole sensor.
Remove either the left or right side engine plastic-junk assys (vent ducts, or air filter box) to gain easier(?) access to that area, slip off hot lead, clean up both lead and plug w/ scotchbrite, reassemble with dielectric grease (Autozone, etc.) and... wait for any re-occurrence.
If it were just outright reading a funny temperature, you could measure resistance, and compare that cold reading against what gray hairs, here, replied it should be.
But intermittent means fix the possible and wait for re-occurrence.
(besides -- such things only happen to coral cars)
-Lonnie
Edit -
And confirming that position (and 'the way in') is this oldie-but-goldie from Garrett (another where-angels-fear-to-tread engine/C4 Guy)
-Lonnie
Edit -
1 Post
Hi JD,
That has happened to me two years ago and it turned out to be the sender. It can be replaced easily without removing the engine. Make sure you replace the the gasket as well if you replace the sender. Andy
Great info guys. Lonnie, thanks for the fantastic search skills. I was unable to find those links when I searched. Given what Jim says about it pegging high if unhooked, I think I will go the route of disconnecting the wires, cleaning the leads, etc. If that does not work I will take Andy's recommendation and replace the sender AND the gasket.
As always guys, thanks so much.
Oh, and Lonnie, Coral Red does cost more to maintain, but looking this good is never easy... I just make it seem that way.
Burgled
Burgled
I need to have a get together at the island for the guys in the Richmond/Va beach area on one of my trips up this summer. We can have a fish/crab/oyster cook out on the water. Its only 80 miles east of Richmond where I am from.
That would be fantastic! My wife is a native Virginian and she talks about needing to show me more of "Mr. Jefferson's Commonwealth" but I have not been to Mathews County. Sounds like a great idea.
sounds like a suaree to crash... I'll bring pretzels. (zinc ointment for the nose... flip-flops...)
why, in a couple week's time I'll be travelin' up the road to West Verginnie to transact with a fellow Renn-visitor for wheels. Drive right thru the area... Small world.
Burgled
