Sachs clutch kit - different part #'s?
I just picked up a new Sachs clutch kit on fleabay at a seemingly good deal, but I am wondering about the part number and application. The box shows:
964 116 911 02, which under the Pelican site is given for 90-91 C2/C4.
For 92- , Pelican shows 964 116 911 01. My first guess was that it has something to do with the flywheel change around MY92. However, the individual pressure plate and disc part numbers apply for 90-94.
Of course, it just so happens that I have a 92 C4. So, does anyone know what the differences are between the two Sachs clutch kit part numbers? And can I use the 964 116 911 02 kit on my 92 C4. Or do I need to trade it in...
THANKS
THANKS
Come on, you tech gurus, consider this a challenge.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Bottom line, quite simple:
What is the difference between a pressure plate for a 90-91 C2/C4 and a pressure plate for a 92-94 C2/C4 ??
Can a 90-91 spec pressure plate be used on a 92?
