964 Forum 1989-1994
964RS replacement trailing arm bushes
Old 12-23-2008, 06:53 AM
  #91
9mrobin
9mrobin's Avatar
Sire,
You should know have a reply sent to you I have been of on holiday the last few days sorry for the late reply.
Peter
Old 12-23-2008, 07:14 AM
  #92
Sire
Sire's Avatar
Peter,
Send you mail. And your excused, but dont let it happen again to go on holliday when i want some bushes ;-).
regards,
Marco
Old 12-23-2008, 12:01 PM
  #93
9mrobin
9mrobin's Avatar
Marco,
YHM all the best for Christmas and have a happy new year you should have your bushes next year lol
Peter
Old 03-01-2009, 02:57 PM
  #94
ghhally
ghhally's Avatar
Can some of you, who exchanged the OEM bushes on the rear traling arm with the ones supplied by Ninemeister, share experiences on installation and final handling during driving.
Thx
Geert
Old 03-01-2009, 07:18 PM
  #95
Jan-Terje
Jan-Terje's Avatar
Can't say anything on performance gains yet. But installation was no big deal. For me the hard part was getting the trailing arms of the car. Had to get a special tool from Porsche (9299) to get the right trailing arm off . The allenhead bolt is so close to the gearbox on the right side.
The tool goes from 12mm allenhead to regular 22mm head, like this:
Then, remove the old bushing by cutting loose the outer rubber parts and push the inner parts out. Basically following the instructions that came with the bushings.
And voila!:
Old 03-01-2009, 07:29 PM
  #96
ghhally
ghhally's Avatar
Thx Jan-Terje.
Sent an e-mail to ninemeister
Geert
Old 03-02-2009, 09:44 PM
  #97
WHITECAR
WHITECAR's Avatar
Hello Peter!
Are these bushings still available?? If so, can you forward me info on how to buy, how much etc..
Thanks very much.
Regards,
Bob Mulligan
Old 03-03-2009, 09:16 AM
  #98
Bill Verburg
Bill Verburg's Avatar
? for Colin, what is the ShoreA # for these rubber bushes?
Old 03-03-2009, 10:39 AM
  #99
NineMeister
NineMeister's Avatar
Just to let everyone know, the bushes are in stock at 9m on the Rennlist special price of £175 plus VAT & Carriage as appropriate.
Sorry Bill but I do not have an equivalvent Shore number for the Poly bushes although I can tell you that we only stock the stiffer material option which is proving to be near ideal for mixed fast road, trackday and racing use.
Old 03-03-2009, 11:54 AM
  #100
Bill Verburg
I believe that stock rubber is 60A and RS is 85A
anyhoo, for those interested in rubber A arm bushes, instead of stock/PU/monoball, Elephant Racing has them for 964/993 front A arms in stock and sport spec. for both the leading and trailing pivot. RS only uses harder bush at one end(need to look up which end)
Old 03-04-2009, 02:33 PM
  #101
ghhally
ghhally's Avatar
Parts received! Really nice stuff!
Old 03-19-2009, 08:47 PM
  #102
ghhally
ghhally's Avatar
Jan-Terje,
will replace the bushings coming weekend. Just to confirm, can you indicate which parts needs to be re-used on below picture? (Thx Jasko).
I'm sure about the 2 outer parts. Any other peices? Washers?
THx
Geert
Old 03-20-2009, 05:52 PM
  #103
Jan-Terje
Jan-Terje's Avatar
I can't recognize removing the two "rings", # 2 from left (green) ? If you read the Fitting Instructions part 1 it says to leave the metal rings.
Apart from that, it is the part # 3 (red) from left which you will want to clean, and re-use.
Old 03-20-2009, 06:36 PM
  #104
demonfish
demonfish's Avatar
for reference - the powerflex fronts come with a new number 3.
Old 04-04-2009, 04:13 PM
  #105
ghhally
ghhally's Avatar
Bushings installed
Have a look https://rennlist.com/forums/964-turb...ml#post6451866
Quick Reply: 964RS replacement trailing arm bushes
