Oil Line Fitting Leak
Hi,
I have an oil leak that looks like it is coming from the oil fitting on the filter housing (not the oil pipe nut).
I have read on another thread that if tightening the oil line nut to make sure the fitting nut does not move.
So my question is can I try to tighten the fitting nut without making things worse and can it be over torqued?
The leak is not to bad and I would live with it till the next service if there is a risk of making it worse.
Hope the pic helps,
thanks
Hope the pic helps,
thanks
Best thing to do is to clean it up really well with some brake cleaner, then run the car and watch where it leaks. Sometimes when lines are removed, the attachment fittings are loosened without knowing, and not retightened - just the line is tightened, causing a leak. If that were my car, I'd clean it up really well, give each fitting a grunt or two to ensure they're tight, then monitor it.
Neat blue car, by the way
Ditto Garrett376...I had a leak on my 89 C4 in the same area. It was the adapter bushing that screws into the oil filter housing. Tightened it, then the hose nut and all is well. Good luck!
Thanks for the replies, had a look today and got a small turn on it (not much room for leverage) so I'll keep an eye on it over the next couple of days.
Is the fitting part of the filter housing or is it sold separately,is there a part no.
cc
cc
I need to replace my oil line that goes from the filter housing to the thermostat.
The fittings on the hose will not break loose, the fitting between the hose and the thermostat and or the filter housing move but the hose fitting will not.
Any suggestions how to get this off ?
I just replaced the line from teh filter housing to the t-stat. Similar problems on removal. Sears has a Crescent wrench that is small, 10" I think, but has a wide jaw and is thin enough to get on the fitting. Another Crescent on the nut gave me the necessary leverage.
Another recommendation - Had my hose custom built at the local hydraulic service shop. They welded the copper tube / nut end sections onto new fittings with new hose. PITA because I didn't know they were going to put the new connection right where the hose goes down through the narrow spot next to the tank. However, after rebuilding that connection to go on the wheel side of that area, everything is bone dry.
Best news, OEM HOSE - $500, CUSTOM HOSE - $100.
Still have this leak after making sure that all the fittings were nice and tight.
I'm going to replace the union fitting (between the filter housing and oil line) and the sealing ring.
I just need to check the part numbers are the same as the fitttings on thermostat end as they are not shown in the PET. The numbers I have are,
90091500809 (union) ?
90012313930 (ring) ?
Page 50 of the PET
Page 50 of the PET
Professor of Pending Projects
