Induction techie Q
Induction techie Q
Hi guys, am playing around with some induction ideas on my car. And know roughly what I want to do, my question is. Is a 3" bore induction pipe going to allow enough air in with my car running about 300bhp and running a hotfilm mod? I ask as this is the only size tube I seem to be able to get!
induction design is all about velocity, pressure and harmonics. 3" will allow plenty of air through at the right pressure and velocity. the question is whether it will flow at the proper velocity & harmonic. also, the static pressure drop per length of that pipe. there are a ton of variables here.
The pipe length will be about 13". The outlet from the cone filter is a tad over
3" and the MAF is about the same, so assumed it would all be well matched.
IHI KING!
I did read that thread but can not see the relevance as I am only talking about the tube from the airfilter to the MAF. If it were any other car I would probably just use a bit of flexi!!
