Exhaust component weights?
Curious if anyone has weighed a factory 964 primary muffler, secondary muffler and catalytic? It would be nice to know the weights to help decide what to remove or replace
i have all three that i can weigh - i'll see if i can get some time this weekend to do it
shoot me an email to remind me. rob@lynchracing.com
- but from memory (rough #'s)
Primary is 25-30
Cat is 10-15
Secondary - 15-20
best bet's
replace Cat - less weight actual pwr
replace primary with bypass - large weight savings
use the seconday only.
or
Delete Cat
use primary
Delete Seconday
this config gives the best pwr from what i have seen - however it is heavier
my prefered config (yet to be dyno'd)
Delete Cat
modify primary (open and remove everything - add perferated straight pipe) should save 10lbs or so
delete seconday
Add cup primary to Tip (G- Pipe w/ built in tip)
hope that helps
Primary is 25-30
Cat is 10-15
Secondary - 15-20
best bet's
or
Delete Cat
use primary
Delete Seconday
Delete Cat
delete seconday
hope that helps
I didn't see the cat in that survey so here's the weights I have
964 cat 13#
left side header 12#
right side header 16#
36.75mm tubes
X-over 64.9x33.5mm
65mm collector
Section Flow Rate (CFM)
Catalytic Converter 442
Primary Muffler 396
Secondary Muffler 462
964 cat 13#
36.75mm tubes
X-over 64.9x33.5mm
65mm collector
Primary Muffler 396
