Thermal imaging...pretty cool!
"erm" is a dontknow/uncertain coment. In this context it means mayb a joke? Messin about.
Is there any reason why had a thermal camera?
Where did you get access to this type ov camera?
Ive only seen that good in iraq. On tv!
Thermal camera
We just picked up the line and are selling them, mainly to maintenance guys at large plants for looking at loose electrical connections, bad steam valves, heat loss, etc.. Great for troubleshooting. They are made by the same company that puts cameras on gunships for the military, and builds night vision stuff for law enforcement. I just took it home to get familiar with it before I take it out to demo for customers. I shot pictures of the Harley and the 911 just for fun to see the heat signatures.
I could be wrong, but I think these images (or images like them, shot for specific purpose) might be interesting in order to understand heat issues related to our engines. What would this image look like after a vigorous run, for example? Is the air more cool at the intake area? etc etc.
Great job, and if you or anyone has any ingenious ideas for using this technology, why the hell not? Isn't the purpose of the forum to know as much as possible about these engines, and this kind of photo might reveal a few things hitherto debatable.
In the pic of the open engine . . . What part/area looks coolest?
Coolest spot
The lowest temp in the open engine bay pic appears to be the A/C line running to the compressor. I think I can manipulate the crosshairs on the camera while still keeping the car centered in the picture. I'm still learning how to run this thing. It would be fun to put it on a lift after a spirited run and get pics from underneath, set the crosshairs on the hot spots and read the temps.
Thermal camera
It is surprising that the vents of the engine cover seem to hold in so much heat.
Good point! Why isn't the heat escaping and showing up on the pic coming out of the vent???? Hmmmmm
Since they 'measure temperature' based on emissivity the 'temperature' readings are pretty much worthless when looking at something with a varying range of material emissivities, such as a car.
Their purpose is for measuring relative surface temperatures like illegal aliens hiding in bushes, or as mentioned troubleshooting hot points/leaks.
They are useful, as we use them, for measuring temperature distribution across a single material such as heat sinks, where you set the material emissivity and get a fairly accurate temperature distribution.
Last edited by ddubois; 11-17-2007 at 02:56 PM. Reason: I meant emissivity, not reflectivity
A contact pyrometer is far more reliable if you need to know an under-hood temperature.
Would be worth perhaps shooting IR pics from a chase car to get a view of how the airflow & heat is moving. Especially if you've got roughly identical cars and one of them has the under-tray!
