Help with aero mirrors
I have a 1990 C2 LHD and bought it with aero mirrors on the car. The driver's side mirror is hanging down compared to the righthand side mirror, as you can see from the pictures. I suspect that this might be the result of fitting RHD mirrors onto a LHD car? I do know that the base of the mirror can be purchased separately from Porsche and that they do differ for right and left hand drive cars. Can anybody tell me if that is the problem with mine? Or am I missing something?
Thanks,
Hendrik
Thanks,
Hendrik
Thanks,
Hendrik
I'm not convinced that either of them are correct. The top of the mirror is far closer to horizontal on mine. I think you need both bases as on mine the bases are wider on the outer side and narrower on the side closes the window than either of your bases.
Someone else who is closer to their car than me (ie in the same country) can probably give you more specific sizes. I'm going off some photos of my mirrors when I mounted them.
Neil
Neil
The right hand side looks about right but the left (drivers?) side looks distinctly wrong. Mine is a left hand drive and the driver's mirror mount looks very different.
Regards
Dave
Regards
Dave
Best will be to get the correct base for a LHD car and check whether they look symetrical. If not, I will order the other base as well.
Thanks again,
Hendrik
Agent Orange
Hendrik, take the mirror off and see what part number is stamped on the inside of the base (it will start with 965 or 968). Post it here and we'll let you know what car it came from.
Left - 965 731 241 01
Right - 965 731 242 01
This the same number you said it should be?
Something is not right. Could it be that your mirror base is not this number?
Is anyone prepared to check their mirrors for me?
It is clear from the photos that these parts are not the same.
Thanks,
Hendrik
Professor of Pending Projects
I still do not get what you think the problem is...
You have the correct part numbers... from the photos I can't figure out what you are saying is incorrect... They still look like the correct part and installation to me...
